I am Sangok An, living in Korea.
I am trying to compare two steel plates—one with bending and one without—using Creo Simulate Lite (9.09). However, the results show that the plate without bending performs better, which is unexpected, and I am not sure about the cause.
Analysis conditions:
I had attached result and parts,
Best your regards
s.o.ahn
Dear skunks
Thanks for your quick answer.
I can't understand of load apply points and constrain conditions.
Can you explain more dedail.
One more time thanks for your help.
Best your regards.
s.o.ahn
it is 1/4 symmetry
Load/4
