I'm working with Creo Parametric 2.0. Many times i'm facing the "fatal error encountered" issue while working in drawing as well as in part modeling.
Please tell me how to resolve this issue.
What M code are you using? I am not there, but I have seen a lot of comment to stay away from M080.
Thanks, Dale
When I worked on drawings with a many datum tags. Trying to re-assign references or moving them would cause a fatal error crash very often. I have given up on using actual datum tags and resorted to an intelligent datum tag symbol for the drawings.
In the last post in the linked post below, there is a symbol attached that you are free to use if you so choose.
What version of Creo are you using, Nandkumar?
And welcome to the forum!
