Flipping model without using mirror function
apansare
Hi All,
I want to flip my entire model (mirror) with respect to top plane in Creo 2.0. I am facing issue regarding feature failure (depended features are failing) if I am flipping first feature.
Is there any possibilities that I can flip my entire model with respect to plane and co-ordinates?
I have attached snapshots simple example of actual model and required model for better understanding. This is very simple example and I have to do this for very complex models.
So any help will be great.
Thanks in advance.
in CR3 you can use:
  • in Part mode File > Save As > Mirror Part ... the symmetry is executed about the XY plane of default coordinate system, you cannot select mirror plane
  • in Assembly mode, select Create in Component group under Model tab and select Part as Type and Mirror as Sub-type > OK
MH
Martin Hanák
apansare
(To:MartinHanak)
I know that option is available in CR3. But currently I am using CR2.
in CR2 you can use Assembly mode variant.
MH
Martin Hanák
  • create new empty assembly
  • assemble your component
  • mirror the component using following steps
  • click Create in Component group under Model tab
  • select Part as Type and Mirror as Sub-type
  • click OK
  • set Mirror geometry with features
  • select part
  • select mirroring reference
  • click OK
  • select assembly, this action saves mirrored part, too
MH
Martin Hanák
