Force and moment on a cylindrical shaft
opavot
Dear All I have to simulate a cylindrical shat with a force and a moment For the force I use a cartesian coordinate system (CS) ,for the moment I found in the PTC datas base , I have touse a cylindrical coordinate system My first problem is that I don't understand why I have to use a cylindrical CS to define the moment ? My second is if I use a cartesian CS for the force and a cylindrical CS for the moment , for sure I will found a wrong result , so can you explain how I have to creat my simulation model Many thanks for your help Olivier
6 REPLIES 6
opavot
(To:opavot)
Hello everybody I saw my question don't inspire you a lot , but if one of you can help me about this... Thank a lot Olivier
Hello Rick On my part , I have a force and a moment *For the force I use cartesian coordinate system *for the moment , I use a cylindrical coordinate system because it's a recommentation from the PTC data base knowledge my first question is to know if I can use a cartesian coordinate system to defind a moment , then I will have the same reference for force and moment My second question is to know why PTC recommande to use a cylindrical coordinate system to defind a moment , is there any special reason ? Many thank for your help Olivier
It's easier to define a point on the surface of a cylinder with cylindrical coordinates. If the orgions of the two CS are at the same point, I don't think you will have any conversion problems. rick you could use Cartesian for both, but it's easier to use cylindrical coordinates to define a point on a cylindrical surface. I don't think the results will be wrong if you use the same origion for both CS. just a guess, make sure you verify this.
Hello Rick Thank for explanations , according your answer I used cartesian coordinates system to define a moment anf I found same results as the one with cylindrical Olivier
