Gear
bmozley
Gear
Creo Community,
How do you get 2 gears to rotate simultaneously (drag components) using
the pin constraints?
I do not have the mechanism module.
Brad
Brad,
Are you sure you don't have Mechanism? It comes with Foundation Adv
seats...or at least that is what they used to be called.
You may not have Mechanism Dynamics, but what you are trying to do does not
require MDO. The MDX app includes a Gear connection.
Hope that helps,
Gavin B. Rumble, PE
Solid Engineering
336-224-2312
