www dot dostips dot com
DOS - Arithmetic How to use SET /A for arithmetic in DOS
DOS - Experimental Stuff Experiments.
DOS - My First Batch File Lern how to write a DOS batch file yourself.
DOS - Powerful Enablers Basic yet powerful features make DOS a quite interesting script language.
DOS - Script Snippets DOS Batch Script Snippets.
DOS - String Manipulation Basic string manipulation in batch like you are used to from other programming languages.
DOS - String Operations Basic string operations in batch like you are used to from other programming languages.
DOS - XCopy Copy Tips Use XCopy for more than copy. I.e. check if a file is open and more...
DOS Batch - Date and Time Using date and time functions in DOS.
DOS Batch - File Examples A collection of batch files.
DOS Batch - FTP Scripts File Transfer with FTP, One-File Solutions.
DOS Batch - Function Tutorial What it is, why it`s important and how to write your own.
DOS Batch - Functions Keep your batch script clean, call DOS functions.
DOS Batch - Interfacing non DOS Software Embed other languages into your batch, like: Perl, SQL, FTP, ...
DOS Batch - Menus Need a menu? See which of these menu frameworks fits your needs.
DOS Batch - Quine Collection Self-Reproducing Batch Programs created by Peter Hartmann, founder of DosTips.com.
DosTips - Sidemap Detailed list of available pages at dostips.com
DosTips - The DOS Batch Guide Home Page
General Contact information, DosTips.com / CmdTips.com terms of use, ... and more
Unit Test Function Library Unit Test for DosTips Functions.
