How do I define a load that rotates from 0deg to 360deg from the original position in Creo?
CZ_10454112
3-Newcomer
Hello everyone,
I would like to simulate the stress vs. load angle in Creo. Instead of creating individual load set for every 20 degree, I would like to see if there is a way to define the load with the parameter relation, and make Creo run the analysis for with a new load for every 20 degree.
The load magnitude will stay the same, but the direction will change. Thank you so much!
skunks
(To:CZ_10454112)
skunks
(To:CZ_10454112)
example att.
Thank you so much!!
Thank you so much for sharing the example! I was able to mimic your steps on my model :D.
I also added some points for measurements, and I would like to export the values from the analysis. I don't see the .csv file of these values saved like what a static analysis does. If possible, would you mind showing me how to get the values out? Thank you so much!
