Can I create a parameter relation with user-defined points in Creo?
CZ_10454112
3-Newcomer
Hello everyone,
I recently ran a sensitivity study with 20N load applied on the model from 0° to 360° from the start position thanks to user skunks's help! I also defined many points to obtain the strain values from the study. I am wondering if anyone knows
1) if I can export the measurements in the .csv like what a static analysis do?
2) Can I create a parameter relation feature in Creo with the user-defined measurements? And then have Creo plot the final results vs. angle?
(Related post: https://community.ptc.com/t5/Analysis/How-do-I-define-a-load-that-rotates-from-0deg-to-360deg-from-the/m-p/830717/emcs_t/S2h8ZW1haWx8a3Vkb3N8TDlCUDlDNUJRSzZWMkZ8ODMwNzE3fEtVRE9TfGhL#M10924
Thank you so much!
0 REPLIES 0
