Hello! Is anybody know where to find the switch to set up surface color of shell elements shown in the above screenshot? I have searched the "Help" provided by PTC, but couldn't find an answer. This is Simulate 6. I have been running random vibe simulations. Thanks. _JS
Hello, it looks like this is the only place to find the "switch". Those "simulation entity colors" don't work. Could you help to explicitly point out which switch has to be toggled? Thanks.
Aha - your theme is black on white.
Thanks_JS
Shrink elements is also useful.
