I am trying to simulate a fluid using to cool a component. Simulate Live fluid analysis reports a constant temperature. Just to try to get any kind of response I applied a 20kw heat load over an area in an internal flow and I can't get the temperature of the fluid to rise at all.
Is Live fluid sim capable of telling you the temp of a solid surface by simulating convection cooling?
I'm using Creo 7
