I need only Rotation in X released. the representation in image is correct or not?
Depends on feature you are using. If it is beam release - than yes. if it is boundary condition than it is wrong.
Than depends on type of element you are applying this feature not all element support rotational DOF.
Give us more information so we can help you.
