Menstrane deformation
DenisJaunin
Would it be possible to load this file that we see on the attached image.
Sincerely.
Denis
skunks
(To:DenisJaunin)
hello denis,
similar example
DenisJaunin
(To:skunks)
Hello skunks,
Thank you for your answer and your example.
I'll look at the file and study it in a moment.
Sincerely.
Denis.
Hello skunks,
I was able to recover the files, but I couldn't run the simulation.
I am w7 pro sp1 32bits, Creo 3 and I may not have enough memory?
Sincerely.
Denis
skunks
(To:DenisJaunin)
Hello Denis,
...32bit...Smiley Sad
...creo3...Smiley Sad
skunks
(To:DenisJaunin)
test in creo 2 or creo 4?
