When using ANSYS Simulation, I am able to solve the model fine. The results show a green check mark. When I plot a result, the color legend shows up. However, the contours do not plot on the part being simulated. In addition, when I click on "display mesh", the part changes from a shaded solid body to a wireframe. The elements do not plot.
Can you help me figure out how to get the e
You can do it only with advanced results
