STARTPARM is enabled and the parameters from the start file exist in the part, but ModelCHECK still flags them as missing.
I believe you need to check the designate box to make the parameters readable by windchill.
What you need should work without STARTPARM at all.
It looks like you have MU_ENABLED set to N in config_init.mc.
