Problem with Measure Force
fstopelli-2
is it possible to fix this problem?
Thank you
FYI ... your picture is not visible.
Martin Hanák
fstopelli-2
(To:MartinHanak)
Thank you
I might try putting stiff springs at each of the weighted links - dependent side and use a force measure on the spring.  maybe, but too busy at the moment to look further.
