Reg: Model Check in Pro/E Wildfire 4.0
  • June 9, 2010
  • 2 replies
  • 1207 views
Hello Pro/E Gurus
Good Day
I am using Pro/E Wildfire 4.0. My part name should be 4 digitIR part number followed by IRxx( Ex: 1B44IR01). I want to check this part name using model check.
Check File has the following parameter
MODEL_NAME YNEW E N N N N
Start file has the following parameter
PRT_MODEL_NAMEEQ*******IR**
is it correct method?. If I give 3 digit number followed by TRxx, model check will not show its a error.
So kindly tell me what is the correct function to write in that start file to check the model name
Thanks In Advance
Suganthan Rajamanickam
Pro-e System Analyst
Trane Design Centre, India
Ingersoll Rand
I took this directly from the help section in WF4. It has some examples of naiming conventions and wildcards that can be used
ModelCHECK can verify that Pro/ENGINEER model names, instances, and simplified representations conform to company-specific naming standards in the following ways:
  • Are file names less than, equal to, or greater than a specific number of characters?
  • Do file names consist of only characters or only numbers?
  • Do file names contain specific strings?
Use the following format in the start configuration file to configure layers:
[MODE]_[MOD_INST]_NAME[equality] [value]
where
  • [MODE] is PRT, ASM, or DRW.
  • [MOD_INST] is MODEL, INSTANCE or SIMPREP.
  • [equality] is the equality relationship. Acceptable values are:
  • EQ—Equal to
  • NEQ—Not equal to
  • LT—Less than (only for length)
  • GT—Greater than (only for length)
  • LTE—Less than or equal to (only for length)
  • GTE—Greater than or equal to (only for length)
  • [value] is the value of the model name. Rules for values are:
  • Do not specify exact values, because each Pro/ENGINEER model has to have a different name.
  • Use ALL_CHARACTERS to verify that all models have names that consist only of characters. This check ignores dashes (-) or underscores (_) found in names.
  • Use ALL_NUMBERS to verify that all models have names that consist of only numbers. This check ignores dashes (-) or underscores (_) found in names.
  • Use LENGTH_## where ## is a number. This check verifies that the number of characters in model names is either less than, less than or equal to, equal to, greater than, or greater than or equal to a specific number.
  • *, ?, # and $ can be used as wildcards, where:
*—Any number of characters
?—One character (numerical, alphabetical, or symbol)
#—One numerical character
$—One string character
  • For DRW_MODEL_NAME, a value of FIRST_MODEL can be specified if you want to check that the name of the drawing is the same as the first model added to the drawing.
  • Specify LIST_XXX to refer to a list of acceptable values.
PRT_MODEL_NAMEEQLIST_NAMES
Specify each member of the LIST_NAMES list on a separate line in the configuration file as follows:
LIST_NAMESCE_*
LIST_NAMESCD_*
LIST_NAMESEO_*
This check would verify that all model names begin with CE_, CD_ or EO_. Alternatively, you can refer to a text file that contains the list, as follows:
LIST_NAMES text/list.txt
For example:
PRT_MODEL_NAMEEQALL_CHARACTERS
PRT_MODEL_NAMEEQALL_NUMBERS
PRT_INSTANCE_NAMEEQXYZ_*
PRT_INSTANCE_NAMEEQGENERIC
ASM_MODEL_NAMELTLENGTH_12
ASM_INSTANCE_NAMEEQE_##_*
DRW_MODEL_NAMEEQCD_*
DRW_MODEL_NAMEEQ???_CD
DRW_MODEL_NAMEEQFIRST_MODEL
Examples of wildcards:
  • *test—The value has to end in test, so model test would be an acceptable value.
  • ??-??—The value has to be five characters long with a hyphen (–) as the third character.
  • ####-$000—The first four characters have to be numbers, the fifth character has to be a dash (-), character number 6 has to be a letter, and the last 3 characters have to be zeros (0).
  • ???_*—The first three characters can be any characters followed by an underscore.
Thank you buddy.
