*** Status Update 2 *** Assembly won't open
ptc-141274
I was able to open the whole assembly!
Thanks to all for the tips and recommendations.
Doug
Here is the latest:
The 3GB switch is utilized, but was set to /userva=2080. I set it to
/userva=2900 as recommended.
I am on a 32 bit machine, and at the mercy of the corporation for a 64
bit machine. Maybe in a year...
Virtual Memory was set to Min: 2046, Max: 4092. Per a recommendation, I
have increased it to Min: 14000, Max: 14000. (3x the RAM).
Not positive if this was opened WF4 before we switched.
It seems inconsistent when I the error message.
At my last error message today, xtop.exe showed 1,464,052K being used.
I was able to open the assembly in a graphics rep. I then suppressed
everything but the 1st assembly (which will open on its own). I was
then successful in opening the assembly in question, in master rep mode.
I then started resuming components. I am about half way through
resuming components. I am also trying to make sure none of the
components have a yellow stop light warning.
Not sure of total file size on disk yet.
Not there yet, but getting closer. Maybe ammunition for a new machine
sooner than the schedule!
Thanks for all the tips!
Doug
0 REPLIES 0
