Structure with commercial extrusion
fstopelli-2
Hi!,
I would like to analize a structure made by estrusion (see attached file),
but generating mesh is very slow, it i possible to increase the speed of elaboration?
are there any simulation tips to follow in this situation?
Thank you
6 REPLIES 6
It depends what you look for. You might use large mesh as default setting and intensify it only where you feel there are bigger gradients. If it is a parte of a bigger assembly (so you are not focused over this extruded bars), you might also use beams by specifying their section in beams' definition.
fstopelli-2
(To:gfraulini)
From datasheet I know Jyy e Jzz but not J
I have to use "Sketch" command?
Yes, you need to sketch your own section.
fstopelli-2
(To:gfraulini)
So what does it mean?
You simply have to put a point where the shear center is within the sketch environment.
https://theconstructor.org/structural-engg/shear-center/3677/
fstopelli-2
(To:gfraulini)
H gfraulini Pearl,
Can I use also a shell element to model the structure?
I seem correct but If I see "Review Geometry shell doesn't appears
