Dear all,
I was trying the inverter tutorial (with no heat transfer) and I get an issue during meshing (Simulation mode).
I've only italian screen, I'll try to get in english soon and attach here.
Fast translation is like:
"Impossible to get tessellation from input geometry. Check geometry. In case of external fluid problem use general tessellation changin 'tessellation type' and retry."
Does anyone get this error?
Thanks for the answer
Hi
There should be no issue for power inverter tutorial model. Could you check bodies you add as the simulation domains? My guess you add merged part too, then tessellation of creo fails. let me know if this works for you.
