Throttle cable linkage mechanism
greeder
7-Bedrock
I am modeling a throttle cable linkage mechanism and looking for methodology to incorporate the wire rope (cable) component.  At one end is the throttle body with associated linkages and the other end is a throttle pedal with its associated linkage, both being connected by a cable.
Thanks for help...
tbraxton
(To:greeder)
This is an old tutorial but will set you on the path to modeling a cable.
https://learningconnector.ptc.com/content/tut-112/belt-features-in-creo-elements-pro-mechanism-dynamics
Involute Development, LLC
Consulting Engineers
