My env is Wildfire4.0 M050.
I got a warning in std.err file - that says "WARNING: (Host-name) appears to have the loopback address 127.0.0.1 as IP address. This may imply that processes on (Host-name) may not be able to connect to non-local processes"
Does anyone know how to solve this warning?? Is this problem??
Hello Hajime, I would suggest logging a case with Support. http://www.ptc.com/support/proengineer.htm
-Dan
