can it is possible to create thermal and structural analysis in Creo Simulate.![]()
Is it possible to do a multiphysics problem - in other words, can I solve a problem that has combined structural and thermal loads? I see 2 separate modes in the software (structural AND thermal)…hence the question.
Short answer: Yes.
Long answer: you need to give more details about what you want to do, to get a better answer.
As Patric mentioned, you need to provide more detail, but you probably want to look into defining your thermal analysis and then you can bring it into the structural analysis as a MEC/T load.
Yes, you can bring in the thermal results via a MEC/T Load.
Yes!! But is it possible in Basic Simulation module or required any Addon
It is not an Add-in or external program. It is built into the Creo simulation package. If it isn't turned on for you contact your PTC rep and find out what package you need to turn that feature on. I am not an expert in licensing.
Ok no worries! Thank you Christopher![]()
