Has anyone done a u-joint drive shaft mechanism? We are having problems with the pro/mechanism sort of drifting. I would be interested in any input you guys may have about this. We put together a drive shaft with two u-joints the input is free to rotate. The whole shaft can be rotated using the mouse. However when we put it in mechanism and drive the input with a servo motor, the run seems to stop almost at the very beginning. Almost as if the mechanism drifted its connections apart through the rotation process.
Any ideas?
alfonso
Alfonso Medina O. Mechanical Engineer
