ecad import in wf5.0
- August 2, 2010
- 6 replies
- 2981 views
i recently had to import a revised ecad (.emn) file from allegro into proe, and i noticed that the resulting model was missing several holes when compared to an old revision of the board i still had in my directory. i then tried importing the new .emn file using both wf5.0 and wf3.0, and it looks like the wf5.0 ecad import window has changed. while most of the changes are cosmetic, the one im concerned about is that the wf5.0 import isnt recognizing the 69 pin holes that should be included in the model (see attached). what happened? is there a config option i have to change, or something im missing from the import window?
any help would be appreciated...
Laura Woodward
Senior Mechanical Engineer
Saab Training, LLC
Orlando, FL
(407) 281-3012
Saab Training USA LLC-Confidentiality Notice:
This e-mail message, including any attachments, is for the sole use of the intended recipients and may contain confidential and privileged information.
Any unauthorized review, use, disclosure or distribution is prohibited.
If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message.
Laura Woodward
Saab Training, LLC
Orlando, FL
(407) 281-3012
