having simulation problem"The model is insufficiently constrained for the analysis."
mabbas
any advice
5 REPLIES 5
DenisJaunin
(To:mabbas)
Hello Abbas,
Your question is too vague.
Could attach your file so that you can see or the problem lies.
Kind regards.
Denis.
unickque
(To:mabbas)
Add more constraints!
I received this error last month. This may be due to I have given constraints on points and I forgot to attach points to geometry with beam element.
But anyway please send some snapshot to have a look in to that.
jitu
Chris3
(To:mabbas)
Did you try the suggestion Mechanica / Simulate gave you when you got this error? If you run a model analysis it will show you which degree of freedom you are missing.
gkoch
(To:mabbas)
Hello Muhammad,
have you been able to solve your issue with one or more of the answers from the thread (or otherwise).
Please let us know and if a particular answer gave you the right clue, consider marking it as correct.
Gunter
