"Midsurface by face pairs"
  • October 28, 2013
  • 4987 views
Is there in CREO 2.0 a function similar to "midsurface by face pairs" that can be found in NX? I used to use it a lot for the design of hydraulic turbines blades...
Best answer by TomD.inPDX
Sweeps like tangent origins, but it appears that chains can have sharp corners. So it worked exactly as you intended.
I added the part file. This is Creo 2.0 full version if you can use it.
In Creo Parametric, this is done with relations. You have several ways to get there including a saved measurement, or to use a feature's value and performing an operation on it (in this case, divide by 2).
Thank you for your answer Antonius, but...do you have an example???
How would you proceed with the two sets of surfaces highlighted?
Can you sketch the approximate solution of what you are thinking the result is? I am not certain of the solution you seek here.
