Hello Folks,
first of all, yes i used the search function, but somehow I could not really help me.
Easy Question:
I want to create a Symbol with a date stamp.
When I insert the symbol, I want the current date that is entered.
In my case, however, appears only the creation date of the symbol when I insert the symbol.
Is there any kind of help about this small problem, what my fault is?
Thanks!
Heiko,
try my test symbol with variable text created in CR2 M070.
MH
Heiko,
MH
thanks Martin, ......
Now I know what what is meant by the variable text.
It works fine!
Thank you!
