ACL and JAVA - Use of OID Value
TomLeoboldt
Hello all,
Does anyone know how to obtain an Element or Node class object based on a valid OID value? I am working on a new AOM-based java application that calls an existing custom ACL function which returns the OID of an element which I then want to get in java.
I am pretty sure this must be possible. I have been searching through the AOM javadoc for a while today and have not found any kind of a "get element by OID" method. Any suggestions would be greatly appreciated.
Tom
BrianJ
(To:TomLeoboldt)
Tom,
Look in the Programmer's Guide under the Acl Interface for DOMOID
method. I believe in Java you can call it by either Acl.DOMOID(oid) or
Acl.getDOMOID(oid).
Brian Jensen
bjensen@bluelid.com
Hi Tom--
You want Acl.DOMOID().
--Clay
Clay Helberg
Senior Consultant
TerraXML
1380 Forest Park Circle, Suite 100
Lafayette, CO 80027
