AOM & DOM javadoc in Eclipse?
ptc-953960
2-Explorer
I've been trying to integrate javadoc for the AOM and DOM classes into
my Eclipse (Galileo - Version: 3.5.1.R35x_... Eclipse IDE for Java
Developers 1.2.1.20090918-0703) without success.
When I select the properties for the referenced jars, aom.jar and
w3cdom.jar, and try to point to the paths, e.g. C:\Program
Files\Arbortext\Editor\docs\javadoc\aom, Eclipse complains:
[warning icon] Location might be invalid. Files 'package-list' and
'index.html' that are typically available at the root of documentation
created by the Javadoc tool have not been found.
Though there is an index.html under C:\Program
Files\Arbortext\Editor\docs\javadoc\aom, there is not a "package-list".
I have also tried the URL:
John,
You can find some more details at:
Thank you, Brandon.
I displayed
file:///C:/Program%20Files/Arbortext/Editor/docs/javadoc/aom/index.html
in my browser, selected and copied the listing under "Packages" in the
top left frame which resulted in (indentation added for this email
listing) the following text placed in my clipboard:
com.arbortext.epic
com.arbortext.epic.cms
com.arbortext.epic.io
com.arbortext.epic.table
com.arbortext.epic.ui
org.w3c.dom
org.w3c.dom.events
org.w3c.dom.ranges
org.w3c.dom.validation
org.w3c.dom.views
which I then saved to "C:/Program
Files/Arbortext/Editor/docs/javadoc/aom/package-list". Then, selecting
the aom.jar in Eclipse, I assigned the directory "C:/Program
Files/Arbortext/Editor/docs/javadoc/aom" and tried the Validate button.
The dialog window with the following appeared: "Location is likely
valid. Files 'package-list' and index.html' have been found.". The
Arbortext classes within Eclipse now have attendant javadoc.
Unfortunately, the org.w3c.dom ones do not... probably because of the
structure of the shipped javadoc being a child in the AOM tree.
At any rate your help got me to a good level and provided me insight to
this problem. Others can follow using the method I described about, or
simply copy the indented packages above (remove the indentation) and
save to their [EPIC_HOME]/docs/javadoc/aom directory.
Again, thank you.
