Ability to publish multiple CAD documents together into Positioning Assembly
shinoki
7-Bedrock
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
PTC Japan member
2. What product and version are you currently running?
Windchill 12.0.2.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
No ability to publish multiple CAD documents together into Positioning Assembly.
4. What is the use case for your organization?
Hope to be able to publish multiple CAD documents together in Positioning Assembly.
For example, it would be nice to be able to specify that CAD documents should be published together when a spreadsheet is imported.
5. What business value would your suggestion represent for your organization?
Improved workability
[Note from Community Management: This post has been moved from the Arbortext ideas to this support forum for better visibility]
shinoki
7-Bedrock
(To:shinoki)
The initial question was "Is there a way to publish a large number of CAD documents to the Positioning Assembly at once?"
A text file listing one CAD document per line could be specified in “publish.positioningassembly.filename” in “wvs.properties.xconf” and published to Positioning Assembly by WVS Jobscheduler Management.
shinoki
7-Bedrock
(To:shinoki)
