I'm evaluating ArborText 6.1 (Editor with Styler) with a 14-day trial license.
Can it export to HTML? I don't see that option anywhere.
Thanks!
Chris
Does your style sheet allow HTML composition?
From Arbortext select Styler > Edit Style Sheet
Select File > Stylesheet Properties
Is HTML File check box checked?
Alternatively, check the .dcf file associated with your dtd or schema.
Does it allow HTML output?
Content like
<Composition>
<Compose type="htmlfile"></Compose>
<Compose type="pdf"></Compose>
</Composition>
You can publish to HTML. File > Publish > HTML file....
There is also an menu pick for File > Save As HTML...
(This latter usage is not as good as publishing).
I see the HTML options if I start from a new document.
However, if I open an existing file (It's an xml file with ArborText comments, so I can only assume that it was created with ArborText), I don't have the HTML options for save-as (or publish).
Does that mean I can't save this particular document as HTML (or is there an add-on I can get that will do this)?
Content like
<Composition>
</Composition>
My Stylesheet Properties had the HTML box checked, but the .dcf file had an empty composition tag, like this:
<Composition></Composition>
I added the <Compose type="htmlfile"></Compose> in there like you suggested, and now I'm able to Publish as an html file.
Thank you so much for your help!
