Arbortext 6 - Compile Document Type
  • January 9, 2012
  • 4 replies
  • 977 views
In the process of upgrading to Arbortext 6, I overlooked the fact that I
need to recompile my old DTDs to support our prior editions. However,
when I went to the Tools menu, "Compile Document Type" is not present.
Does anyone know how to get this back, or what the preferred approach is
for 6.0?
keith
    berard1-VisitorAuthor
    Aah, it seems removing the old .pro, .ptd and .dec took care of it. Not
    that I'm complaining, one less step for deployment, but I guess I got used
    to having to pre-compile first.
    You still have to compile SGML doctypes in 6.0. In any case, you can just type "compile_doctype [path to DTD]" on the Arbortext command line and it still works the same in this mode in 6.0.
    Somewhat of a late reply, since I was able to get around this in the past.
    When I try the compile_doctype command in 6.0, I get the error:
    The "compile_doctype" comman is not supported in this installation.
    Has anyone else run across this?
    Hmm, it seems that touching a blank template.xml file in the same dir fixes
    the problem. I have a case opened with PTC get their take, and will
    report my findings.
