Hi Adepters,
Does Arbortext Editor 5.3 M111 has support to Schematron? Or
Your suggestions in implementing the same are appreciated.
My requirement of Schematron implementation, is to run as a follow on process when “check completeness” toolbar option is executed, and any schematron errors should show up in “Arbortext Editor Completeness Check” window.
Thanks in advance,
Suresh.
Hi Suresh,
Schematron support came in version 6.0, if you have active support & maintenance you can go to the HelpCenter and do a search on Schematron for details.
There may be a way to support it in version 5.x with customisation, for examplein the S1000D solution there was Schematron capability pre 6.0
Cheers
Pete
Hi Pete,
Thanks for your response.
We are currently using Arbortext Editor 5.3M111.
Could you please provide me a pointer to Schematron Customization?
I could not able to find S1000D solution in my Arbortext Editor installed location.
Thanks in advance,
Suresh.
Hi Sudesh,
I'm afraid I've no idea where you can start with customising Schematron in pre 6.0, someone more technical on this forum may be able to help.
In regards to the support of Schematron in the S1000D solutions, please contact - for advice.
Cheers
Pete
Thanks for your response Peter.
Can someone in the group throw some light regarding customization of Arbortext Editor 5.3M111 for Schematron Support.
Suresh
