We've had new releases for both Arbortext Editor/Styler/PE and Arbortext Advanced Print Publisher come out today! They are available for download from the PTC support site.
Arbortext Editor/PE/Styler 7.1 M060: Key Highlights
Documentation
Download
Arbortext Advanced Print Publisher 11.2 M060: Key Highlights
Documentation
Download
There are two issues in your links above (for Arbortext Editor/PE/Styler 7.1 M060: Key Highlights).
2. "SPR Fixes" (link is: https://www.ptc.com/en/support/refdoc/Arbortext_Editor/7.1/prodrel_fixes_m060 ) - here is a blank page at all:
2. "Release Notes" (link is: https://www.ptc.com/en/support/refdoc/Arbortext_Editor/7.1/ArbortextRelNotesM060 ) - link to PDF file does not work (link is: https://www.ptc.com/support/-/media/3DD098F2F82A4D83A62E158CFDADDCD6.pdf?sc_lang=en 😞
All other links to pages and documents open normally from your first message.
Pushpinder, the Release notes and the SPR fixes links do not work.
Bryon
The links will work if you are logged into the PTC Support site. Can you try again and let me know if you are still having issues?
It goes to the article for the release notes for editor and Styles but you can't open the PDF attached. It goes to the redirect page. Also, is there a compatibility matrix for M060? I can't seem to find one.
