Arbortext Editor/Styler/PE 7.1 M060 & Advanced Print Publisher 11.2 M060 now available for download!
Pushpinder_Toor
We've had new releases for both Arbortext Editor/Styler/PE and Arbortext Advanced Print Publisher come out today! They are available for download from the PTC support site.
Arbortext Editor/PE/Styler 7.1 M060: Key Highlights
  • Support for audio/video in XML Editing
  • Improvements to Notations editing
  • Also includes customer critical bug fixes
Documentation
Download
Arbortext Advanced Print Publisher 11.2 M060: Key Highlights
  • This release includes customer critical bug fixes
Documentation
Download
There are two issues in your links above (for Arbortext Editor/PE/Styler 7.1 M060: Key Highlights).
2. "SPR Fixes" (link is: https://www.ptc.com/en/support/refdoc/Arbortext_Editor/7.1/prodrel_fixes_m060 ) - here is a blank page at all:
2. "Release Notes" (link is: https://www.ptc.com/en/support/refdoc/Arbortext_Editor/7.1/ArbortextRelNotesM060 ) - link to PDF file does not work (link is: https://www.ptc.com/support/-/media/3DD098F2F82A4D83A62E158CFDADDCD6.pdf?sc_lang=en 😞
All other links to pages and documents open normally from your first message.
Pushpinder, the Release notes and the SPR fixes links do not work.
Bryon
VladimirN
(To:bfriesen)
 The links will work if you are logged into the PTC Support site. Can you try again and let me know if you are still having issues?
byork
(To:VladimirN)
@Pushpinder_Toor
It goes to the article for the release notes for editor and Styles but you can't open the PDF attached.   It goes to the redirect page.  Also, is there a compatibility matrix for M060? I can't seem to find one.
