Arbortext IsoDraw reimport txt from XML file with macro
  • May 1, 2014
  • 3297 views
Hi all,
I would like to create a macro to reimport the text (with Object ID) present in an XML file into a .iso file.
My knowledge of IML is very basic (but at the end I manage to create a macro to apply the ID and export into XML ).
Please have a look at the attached and let me know if somebody out there can help me?
Thank you in advance
Max
To apply the xml against the iso file you just need to open it while having the iso file open.
Untested, but this should work. The space in your file name might be an issue though.
Macro Import_XML
Define noExt as String
Define XML as String
noExt= StripExt(ActiveDoc.Path)
XML = noExt + '.xml'
Open XML
End Macro
mcardella1-VisitorAuthor
Thank you very much Trevor,
this macro works for 1 file at the time, but unfortunately I work with a lot files at the time.
Usually I have 40 files ISO in 1 folder and 40 files XML in another folder, any tips?
Cheers
Max
Hi Trevor,
Sorry for delay, the macro works better but it is not fully automatic. (I have to select each xml file every time ), what I need is have automatic re-importation. Any suggestion to solve this?
Thanks in advance
Max
