After I drag the CP folder into the Arbortext Editor application folder, I see the "Change" Menu as well as Change Page Help menus in Arbortext. However when I go to "create basic document" in the Change menu I receive an error message. Do I need to run a license manager? Do I drag some license info somewhere?
Arbortext Change Page for Defense application requires:
Arbortext Editor
Arbortext Publishing Engine
You need at least 1 Arbortext Editor license and 1 Arbortext Publishing Engine license
Both licenses also need to be licensed to use the Arbortext Change Page for Defense application
Tim
Arbortext Editor
Tim
Bryan,
Did the information provided assist you, or do you have further questions?
Tim
Tim,
This issue is resolved thank you.
Bryan
