Can I use a system variables to specify an XSL in a datamerge DMF file?
Hi Folks,
I have a datamerge setup that requires an XSL to structure the result set. Currently the path must be hard coded to something like C:/DataMerge/Transform.xsl for it to work. I would like to keep the XSL file within the custom folder structure in Arbortext - so is ther a way to use a system variable instead? Does anyone know of some tricks?
<TransformerRef name="t1" nameref="XSLTransformer">
<ResourceEventListenerRef name="logger" nameref="DefaultResourceEventListener">
</ResourceEventListenerRef>
<ParameterRef name="p_stylesheet" nameref="stylesheet">
<Value>C:/DataMerge/Tranform.xsl</Value> <<-- Currently the only way to make this work
<Value>%ARBORTEXT_HOME%/custom/datamerge/Tranform.xsl</Value> <<-- Ideally we would like this to work
</ParameterRef>
Thanks in advance for any suggestions,
