Hi everyone!
I tried to create a trialkey for Arbortext with my Host-ID using this page.
I entered my Host-ID like this 00-11-AA-BB-22-CC (not my real Host-ID), but I get redirected to this error page all the time.
Can you tell my, why I cannot generate a license file?
Hi Ruben,
Not sure what the issue is (site-based or process-based), but the following threads may be of use. Please let me know if they are:
Evaluation License Key Not Received
Unable to find license key for trail version and CMS connector details
Hi Ruben,
Did the suggestions given assist you with resolving your issue?
If so, then could you mark the communication as correct, so that the community can build a valuable knowledge base.
If not, then if you resolved the issue, then could you post the resolution and mark it as correct?
