Center lines missing while working with illustrations in IsoDraw 7.3
aselvaraj
7-Bedrock
Recently i am facing problems with isodraw 7.3, when we are working on illustrations suddenly the center lines disappear. if i 'zoom in' or 'zoom out' the center lines appears and disappears. Graphics could be the problem? Help me solve this issue.
Aravind
Thanks Denise, we have solved the issue.
Try reducing the resolution of the screen.
It worked for me, i am not facing center line disappearing issues now.
Hope it will work for you too.
Aravind
I've seen the same problem and what seems to work is to view the drawing in "Preview" and save as a CGM. If you see the same problem in Preview, then do a "Select All" and see if the lines are there. You can also save the drawing as an EPS and see if that helps.
Aravind
