This is an appeal to those in this forum who have worked with Epic Editor and S1000D (schemaor DTDs). I've been tasked to do an eval of Epic Editor (rather quickly) but first I have to learn how to use it.
We are about to collaborate with a client to update their aviation manuals. They use Arbortext Epic Editor (version unk) and we use Framemaker 7.2. We are in two minds: there is some thought that we should get Epic while there is other thought that we stick with Framemaker, as long as we can get their DTDs. I've gone through the tutorial and looked at the templates that come packaged with Epic. I've tried to plunge straight in and import/use an S1000D DTD but I can't find/don't understand how Epic does it (beside the fact that when I clicked on Import in the menu, I was told I didn't have the licence). I know how to do this in Frame but I want to give Epic a chance. Could someone please advise me or point me in the right direction to where I can get the info.
Help appreciated. Cheers
Carl Sarelius
Technical Author
BAE Systems
Hello Dan,
I suppose I was thinking relative to the Frame model, where I can open a DTD, create my EDD, add formatting rules to it and create my template. But the ability to create a structured document based on an S1000D DTD/schema is important. I gather from your reply that for Epic to be able to edit S1000D structured documents I need plug-ins and/or other applications other than Epic Editor. At the end of this eval I need to be able to tell my manager that we can, using Epic Editor, use an S1000D DTD/schema and create a template - complete with formatting rules - to create structured output. So in answer to your question, yes I want to go down that path. BTW, I only have an eval licence from PTC hence some things aren't working eg. Architect, which came with the download package.
Cheers
Carl
In Reply to Dan Vint:
Import is not what you think and it is a separate product or I see if
your following the instructions in the help file, it sounds like you
don't have the architect product licensed. architect makes the
process a little easier but isn't strictly needed. do you really need
to worry about s1000d specific dtds? the raw editor is not going to
do anything special for s1000d content, so if you are just trying to
see how epic works with xml, just select file new and use one of the
dtds pre packaged.
for s1000d there are specific plugins that add customizations for
s1000d and will also integrate with a csdb if you are using one.
my bias is to always use a native xml editor over frame or other
products - you will get into fewer xml problems.
if you want to look at s1000d without one of these plugins, you can.
you have to get the dtd/schema setup. this can be done without
architect and we can get you going with that but it takes some
patience. let me know if you need to go down this path.
..dan
Ian Boulton
Manager, NA S1000D Client Services
PTC
Thankyou Dan, Alexander, Andy, Greg, Elizabeth and Ian,
your answers were concise, confirming what I was already starting to think from my attempts to use the S1000D DTD with Abortext Editor: basically that I need to do/get a lot more before I can start editing documents, and producing SGML/XML, using just Editor.
From my end, in a former company I have had experience using S1000D (v2.2) with a CSDB, Framemaker was our authoring tool, and usingthe various DTDs was relatively simple. Now I'm in a different company, different toolset different ideas.
Thanks all for your input, you've been a great help.
Cheers
Carl Sarelius
Technical Author
BAE Systems Australia (Aerospace)
Hello Carl,
I have been heavily involved with Arbortext Editor (formerly Epic Editor ) and S1000D; I also worked for BAE Systems,UKfrom 2001 developing and maintaining their Arbortext applications which included S1000D application amongst others. I was made redundant end of last year and have now set up my own company, Structured Information Ltd,providing the same capability and things are going well so far.
In order to generate the S1000D templates you will need to :
If successful, you should see <dmodule></dmodule> within the editor window.
You can now go ahead and create valid S1000D data modules however, it won't be easy without a stylesheet to help you.
In order to create the stylesheet or FOSI you will require training and you will also need to purchase Arbortext Architect.
A simpler method is to purchase a prebuiltS1000D application.
If you are interested, I can provide you with a quote.
Andy
