I am using Product "Arbortext Editor with Styler" with Version 5.3 M120.
Although we use Styler as our source stylesheet, We also have FOSI code, and FOSI is the final stylesheet delivered to Client.
After association of FOSI files to Edit widow and Print, Is there a way in "Arbortext Editor with Style" Edit window through which we can find the matching condition for a particular cursor position in Edit window?
I am aware of the following command:
fed_eic at the command-line, but this will open a matching context for a particular cursor position in Edit window.
But my requirement is to get a matching condition with in a context for a particular cursor position in Edit window.
All your inputs are really appreciated.
Thanks and Regards,
Suresh
Hi Gareth/All,
Sorry, It looks to me that may be I was not much clear about my requirement. I would re-frame my requirement more clearly.
I would like to know matching condition of FOSI code for a particular cursor position in Edit window.
Though I am using Epic with Styler, My association for Print and screen Stylesheet are both FOSIs.
If I have a FOSI association stylefile for Epic Editor view or screen view and for a particular cursor position, I would like to know what would be the appropriate matching condition of a specific context of FOSI code?
fed_eic at the command-line, but this will open a matching context of FOSI code for a particular cursor position in Edit window.
But my requirement is to get a matching condition with in a context of a FOSI code for a particular cursor position in Edit window.
I really appreciate your response.Thank you.
Suresh
Suresh,
Since you're talking about FOSI, I'm not sure how Styler will handle the command, nor do I know if Styler will still give you the windows from Architect (the FOSI developer app).
What you can try is to position your cursor where you want to know the context for FOSI needs, go to the command line and type "modifyeic" and press <enter>. Assuming that you've got your document type pointing to the default FOSI for the document type, it should give you the "Style Catagories" window that shows you everything about the e-i-c you're positioned at.
Hope this helps,
Bob
