Error in Arbortext
JE_11013556
Error in Arbortext
Hello everybody, can somebody help me? I'm using Arbortext 8.2 but can't preview or export PDFs because the PTC Arbortext Publishing Engine isn't configured. Somebody can provide me steps on how to fix this error.
Alexia
(To:JE_11013556)
The first question is 'do you have a Publishing Engine' License?
If you only have an Arbortext Editor license you will not be able to publish content, you will only be able to Edit content.
There are many Knowledge Base articles available on the main PTC Support Site that will assist you or the Help Center topics.
You can check your license.txt file which will tell you what products you have licensed.
I hope this is of help
Alexia
Alexia
8 REPLIES 8
Alexia
(To:JE_11013556)
Alexia
Alexia
JE_11013556
(To:Alexia)
Hello, Alexia. Thank you for your feedback. Currently, we only have Arbortext Editor, Arbortext Print Composer, and Arbortext with Styler License. Is there any missing license why we can't preview or export PDF or just the Publishing Engine License is missing?
Editor will use the print composer license to publish and styler has publishing built in. When you install editor you need to ensure that you have selected to install the print composer option. Can you publish from styler?
Bryon
manpsingh
6-Contributor
(To:JE_11013556)
Could you please tell me what is the error message you are seeing?
Are you publishing through Arbortext Editor or Arbortext Editor with Styler?
If you’re getting errors related with PE URL is not configured etc., and you are also not using Publishing Engine then you can uncheck the PE URL option from Tool > Preferences > Publishing Engine and uncheck the option and retest the use case.
Manpreet Singh
Alexia
(To:JE_11013556)
Please go to 'Tools > Preferences > Publishing Engine' and uncheck the box for 'Use Publishing Engine'.
Then Editor should be able to use your Print Composer or Styler license to publish to PDF.
I hope this is of help.
Please let me know how you get on.
Alexia
JE_11013556
(To:Alexia)
Hi Alexia, "Use Publishing Engine" already uncheck but still unable to preview or export PDF.
Alexia
(To:JE_11013556)
In Editor, please go to 'File > New > Docbook > Arbortext XML DocBook V4.0', select 'Sample' and 'OK'
Then go to 'File > Publish > PDF' - Does this shipped sample publish?
If 'Publish > PDF' is not available to you - please go to 'Help > Session > components' and this should show you what licenses are available.
It may be that Editor is not finding your Print Composer or Styler License
Alexia
Alexia
(To:Alexia)
Styler automatically allows publishing - what happens if you go to the Styler menu and publish to PDF from there?
Print Composer is a Standard Feature with a Styler License
Are you able to access Styler or when you go to the Styler menu and Edit stylesheet does it return the following:
I would recommend raising a Support ticket with the PTC Support Team for further assistance.
Alexia
