FOSI: It's not possible to savetext an element and fill an attribute with variable content ....
naglists
For example, one can't make one of the following savetexts work:
<e-i-c gi="dtdelement"...&lt;br"/><savetext textid="myvar1.txt" conrule="!&lt;myelement&lt;br /&gt;myattr="!,#CONTENT(dtdattr),!"&gt;!,#CONTENT,!&lt;/myelement&gt;!" placemnt="before">
<savetext textid="myvar2.txt" conrule="\&lt;myelement&lt;br /&gt;myattr="\,#CONTENT(dtdattr),\"&gt;\,#CONTENT,\&lt;/myelement&gt;\" placemnt="before">
dtdattr is CDATA and the possible values are endless ...
Later I want to <usetext conrule="myvarX.txt"&lt;br"/>
Or am I wrong and there is a magic conrule recipe I'm missing that will
achieve this?
Paul Nagai
10 REPLIES 10
bibach
(To:naglists)
Hey, Paul...
There is a feature which, as far as I can tell, is undocumented, but is
used by Styler to do something like this. It seems to be supported in
later 5.3 versions (M210 has it, but M010 does not appear to), some 5.4
(M050 has it) and all 6.0 versions. You can probably see if it's supported
in your version by searching for "SETATTR" in
packages\main\_styleexportfosi.acl, which is the code that transforms a
Styler sheet into a FOSI.
I haven't tested this, but based on how Styler uses it, something like this
may work:
<savetext textid="myvar1.txt"&lt;br"/>conrule='!<myelement>!,#SETATTR(myattr,@dtdattr)#ENDSETATTR,#CONTENT,!</myelement>!'
placemnt="before">
The part after the comma in the #SETATTR is an XPath, so you should be able
to put just about anything into the attribute with that construct.
-Brandon 🙂
Oooh, undocumented FOSI tricks give me itchy fingers. I might have to go
play with this today.
Thanks, Brandon.
On Sat, Aug 18, 2012 at 1:03 AM, Brandon Ibach <
brandon.ibach@single-sourcing.com> wrote:
> Hey, Paul...
> this may work:
> <savetext textid="myvar1.txt"&lt;br"/>> conrule='!<myelement>!,#SETATTR(myattr,@dtdattr)#ENDSETATTR,#CONTENT,!</myelement>!'
> placemnt="before">
> able to put just about anything into the attribute with that construct.
> -Brandon 🙂
Thanks for the pointer, Brandon. 6.0 m010 does support #SETATTR. And, I
think I am close. Hopefully I just need some XPath help addressing
namespaced elements ... or, I fear, the namespaced attributes are "hidden"
from the #SETATTR code somehow.
Specifically, I am trying to capture the value of atidlm:targetLocator on
element atidlm:resourcepair. I can use standard FOSI fillvals to capture
and save other atidlm:xxxxx attributes on atidlm:resourcepair. But I can't
get #SETATTR to access it.
The following will produce a working link leveraging an existing
<my_link_element> e-i-c:
<savetext textid="my_link.txt" conrule="!&lt;my_link_element type="http"&gt;!,#&lt;br /&gt;SETATTR(target,"&lt;a style="COLOR: blue; TEXT-DECORATION: underline" target="_BLANK" href="http://google.com")#ENDSETATTR,my_targetName.txt,!&lt;/my_link_element&gt;!" &quot;=">http://google.com")#ENDSETATTR,my_targetName.txt,!</my_link_element>!'
placemnt="before">
But this does not:
<savetext textid="my_link.txt" conrule="!&lt;my_link_element type="http"&gt;!,#&lt;br /&gt;SETATTR(target,@atidlm:targetLocator)#ENDSETATTR,my_targetName.txt,!&lt;/my_link_element&gt;!" <br="/>placemnt="before">
Does XPath require something magical to "see" an attribute in the atidlm
namespace?
I notice that much of the code using this (maybe all) uses the string
function like this:
#SETATTR(myattr,string(@dtdattr))#ENDSETATTR
It didn't help in my case.
Any thoughts?
> Hey, Paul...
> this may work:
> placemnt="before">
> -Brandon 🙂
Ok. This is just wrong. I dropped the namespace prefix and tossed this Hail
Mary:
<savetext textid="my_link.txt" conrule="!&lt;my_link_element type="http"&gt;!,#&lt;br /&gt;SETATTR(target,@targetLocator)#ENDSETATTR,my_targetName.txt,!&lt;/my_link_element&gt;!" <br="/>placemnt="before">
The SOB worked. Again, that's just wrong. But, uh, ok, I'll take it.
I've noticed wonkiness in handling of namespaced elements and attributes
in Arbortext's XPath handler as well. I can't really explain why your
approach here worked--I agree it's not correct behavior, but I also
understand not looking a gift horse in the mouth. 🙂
For future reference, my usual workaround when I need to handle
namespaced stuff is to use the local-name() function, something like
this:
SETATTR(target,@*[local-name()='targetLocator'])
--Clay
Clay Helberg
Senior Consultant
TerraXML
SHHHHHHHHH!! If you mention that it isn't correct behavior, they'll fix your gift horse in a couple of M-releases 🙂
bibach
(To:naglists)
Yeah, I wouldn't expect that to work, either, but no complaints as long as
the job gets done, right? 🙂
As for a sort-of explanation, the "real" name of a namespaced attribute is
the actual namespace URI combined with the local name. The prefix is just
a syntactic shortcut. So, the XPath engine needs to be able to resolve
that shortcut to the same URI. You might expect that it could just get
this information from the document you're navigating, but that can prove
problematic, as your style sheet would not work if some document used a
different prefix for the same namespace. So, the usual rule is that the
"host" of the XPath engine (FOSI, in this case) provides the means to
define prefixes, though I'm not sure, offhand, what the rules are on that.
All that said, I think Clay's approach is the safe bet. You could go one
step further and do something like:
@*[name()='atidlm:targetLocator']
or, if you're at all worried that the prefix might ever be different:
@*[local-name()='targetLocator' and namespace-uri()='
Odd. On a different e-i-c the @targetLocator syntax didn't work. Clay's
suggested syntax, however, did.
Now I'm using #SETATTR(ID,@*local-name()="targetXmlId"])#ENDSETATTR which I
declare as CORRECT so no changing that in future m-releases, please! 🙂
I didn't test Brandon's variations ... but prolly they work, too.
Thanks, everyone. Nice trick!
Hey, Suzanne: This adds up to another page in your book! 🙂
On Mon, Aug 20, 2012 at 1:39 PM, Brandon Ibach <
I know it! Curse you! 😉
Suzanne
Hmmm, I see Brandon is to "blame." 😉 Actually, I'm delighted to know about the undocumented #SETATTR feature -- I could have used it myself in the past!
Now it is documented. PDF is attached. All comments welcome.
BTW: If anyone knows of any other undocumented features I should put in the book, please let me know asap.
Thanks!
Suzanne Napoleon
www.FOSIexpert.com
"WYSIWYG is last-century technology!"
