Graphics in sub-directory
goreggioni-2
2-Explorer
Again troubled with images...
I'va tried to set the graphics path in the preferences of the editor (Arbortext 6 M010) as a sub-directory but whatever the way I write it it doesn't work:
I have all graphics in a sub-sub-folder named "cuadernoestudio/images_xml" and in the graphics path I've tried with the proper use of colons and all variations of " and "/"):
"cuadernoestudio\images_xml"
______________________________
Hi Gabriel--
Did you try prefixing the path with a dot "." (for current directory)?
Try this:
"./cuadernoestudio/images_xml"
--Clay
Clay Helberg
Senior Consultant
TerraXML
1380 Forest Park Circle, Suite 100
Lafayette, CO 80027
Hi Clay,
No, It doesn't work.
Before having to reinstall the Editor, I would like to know if I I'm missing something, or It's simply a malfunction of my Editor...
Gabriel Oreggioni
If there is a finite number of paths preceding your "cuadernoestudio\images_xml" directory, you can list all of the potential paths separated by semi-colons.
i.e.
pathA\cuadernoestudio\images_xml; pathB\cuadernoestudio\images_xml; pathC\cuadernoestudio\images_xml; etc. etc. I don't know what the limit is on the number of paths you can use, or if there is a limit at all.
If the possibilities are infinite, then I have no more suggestions, other than to tell you to place all of your images in the same folder(s) on the network and use unique filenames.
