How insert an XML comment? ( <!-- -->)
sfogel
Hi, all...
In the normal authoring view of Arbortext Editor, how do I insert an XML comment? We're using DITA, so we can always insert a <draft_comment> element, but DITA is particular about where this is allowed. I want to be able to insert an XML comment anywhere, so how do you insert this markup without going to untagged view?
Thx!
Steve
ebenton
(To:sfogel)
The insert comment menu selection and Alt+Ctrl+M are disabled? They are not disabled in Arbortext Editor 5.2 DITA topic sample doctypes.
We just upgraded from 4.3 to 5.4 and it crashes if you try to insert a comment. If you comment out a line in a text editor then open with arbortext, the entire program crashes with a C error.
