Good morning,
I am using Isodraw 7.1, below is the whole task and the help section is my main query. I should be able to make the rest fo the macro.
Task
I need to find a text element with certain text inside and then check the distance between this text element and the next text element directly below this. If the distance does nto match a specific number then it needs to be modified.
Help
Thank you for your time
Alan
Hi Alan.
2. For any element you can get the surrounding box. E.g.
y_dist = elem1.box.bottom - elem2.box.top
1. I would try select a rectangle below your first text. E.g.
Select Rectangle x1 (y+d1) x2 (y+d2) WITH_PARTIAL
# To sort out other element types:
SubSelect If Type is equal to "Text"
Cheers, Benno
