Hi Adepters,
If margins in a page set are set to 1" right and left, what could cause the output to behave differently? The left margin is less than an inch and the right margin displays as more than an inch.
We're using a table to build a front cover with these right and left 1"margins. The margins are just the beginning of a whole host of very specific measurements that are wacky in the output. i.e., we need a column that is 4.4", and have to set it in Styler to 4.62" to have it print correctly. The 'conversion' doesn't appear to be consistent.
Has anyone seen similar behavior?
Best,
Anne
Hi David, Suzanne,
Thanks so much for your responses. I'm sorry too that this reply is tardy- I thought I registered a response.
In the end it appears our problem was with Print settings- arg! There was default page scaling setting, 'fit to printable area.' Upon removal of this setting, all is as one would expect.
Kind regards,
Anne
