IsoDraw 7.3 Fillet
khoward
7-Bedrock
IsoDraw 7.3 Fillet
I am using IsoDraw 7.3 build M080 build 6 currently. I am working on creating a graphic and was using the "Fillet" command and all was well, then all of sudden the program stop trimming the ellipse and the line segments. I have tried exiting the program and coming back in with no luck.
Has anyone had this happen? I don't know if I might have hit a key or something. It is really puzzling that it was working fine then all of sudden stopped working correctly.
Any thoughts or suggestions are welcome.
Keith
Have you renamed the preferences file under the C:\Users\username\AppData\Roaming\PTC\IsoDraw\Preferences. We found that when things go sideways with Isodraw this is a good place to look as it stores the preferences.
Bryon
Thanks Byron.
I did have to replace that file I will check it out and make sure everything is correct in the file.
Keith
