We are using Isodraw local and via CSDB, we are not able to update .prf file for the version in CSDB same as the one local???
Somebody have idea where i could find location of .prf for the CDBD???
Thanks a lot!!
C:\Users\USERNAME\AppData\Roaming\PTC\IsoDraw\Preferences\ for a standard user. Not sure if yours is in the same location.
Bryon
Thanks Bryon,
We are using 2 licence of Isodraw, one for creatin illustrations local (but server licence) and one to import illustration into our publication system via PTC CSDB S1000D.
For the local Isodraw your right! it is located in our C:\Users\USERNAME\AppData\Roaming\PTC\IsoDraw\Preferences
but we have issue one the one in CSDB. We are trying to update the same custumize pref in both version without result. We dont know where it is located??? that cause huge problemes or Hatching substitution and linetype in our final publication... all our illustration hiden line, doted line, leader line with dot, leader line with arrow and all our Hatching change... major issue with our custumer...
Thanks a lot!!
We have found that not having the templates installed also causes issues, they could be located here:
C:\Program Files (x86)\PTC\PTC Arbortext IsoDraw 7.3\Program\Templates
or
C:\Users\USERNAME\AppData\Roaming\PTC\IsoDraw\Templates
The templates should be in one location only, not both locations.
Bryon
we got it into our
but not the other one... i call our IT to transfer it, Admin role is required for us... I test that and came back for result!!!
Thanks again!!
puting pref into
C:\Program Files (x86)\PTC\Arbortext IsoDraw 7.3\Program\Preferences
also
did not solved our issue... problem still active...
